Thanks for your answer!
taki--jeden napísal: ↑17. Januára 2023, 10:07When everything is connected as it should be then all is fine. In settings I can choise if radio should switch off when key is out or after 20 minsMartinFastred napísal: ↑17. Januára 2023, 10:03 Hi, Im about to change also from 8 to 10,25 inch. But I read on the forums that the radio is not switching off after you turn off engine. I have the same car as you. Does it work correctly or do you need to shut the radio off by yourself?
Everything else works good?
Thanks
taki--jeden napísal: ↑17. Novembra 2022, 19:27
Yes plug and play. Just antena power is necessary otherwise radio reception is poor
